Misc. 258 Weber fuel pressure regulator return plumbing?
Hi,
I learned enough just looking around on this forum that I wanted to sign up and learn more. My only engine experience is read, research, and attempt. I'm going to try a Weber pressure regulator to determine if it will help my Weber 38 to start up again. This regulator has its own return line. I'm trying to determine if I should keep the original type fuel filter with its return line or if it should be replaced with a basic inline filter since the regulator has a return line. I did see a comment that the filters return line is also a vapor vent and I have not learned if the Weber does that. I'm going to try to insert an image of what I think should work. If anyone is very knowledgeable about this, please let me know.
Thanks.
Thanks.
