304 to 360 swap in California, has anyone done this?
rumblephish
- Central California
- 1978 Jeep CJ-5 "Levi's" edition, original AMC 304 V8, T-150 transmission, Dana 20 transfer case, AMC 20 rear end. All stock except for a hotter ignition.
I'm looking at having to rebuild the AMC 304 in my '78 CJ5 . After considering various option and running across a 360 short block for a good price I've decided I would be better off swaping a 360 in place of the ole'304. BUt here is my dilema.... I live in California.
I'm pretty familiar with the AMC platform and I'm aware of most issues that will come up in this swap, mechanically speaking. Flywheel, oil mod, ect... But since the CJ5 was never offered with the 360 in 1978 will I have an issue getting it to pass the emission requirments of California? I'll be using all of the smog equipment off of my 304 (air pump, egr, ect.) and I plan on running the Edelbrock RPM Gap intake, Edelbrock shorty headers w/airtubes, Edelbrock or Summit (RV) cam, roller rockers, Jacobs "Mileage master" ignition (from my 304) and some head work (3 angle valve job, port/polish, ect..). I fully expect this motor to pass the tail pipe emissions test but it's the visual test I'm concerned about. I realize that it looks almost identical to a 304 but I dont want to chance a picky smog tech looking for numbers on the block.
So has anyone done this swap in California recently (last 5 years or so)? If so what issues did you run into? Is as straight forward as it seems?
Thanks,
RP
Thanks,
RP
