Build Thread 3rd time down the rabbit hole...
Getting ready to buy a new radiator for mine soon for my new engine. What brand did you get ? Have you ever eaten at Don Marcelino's in Del Rio. ? Started eating there probably 33 years ago when I would pass through that area. Heard a while back it had changed, but then what hasn't
Just wondering, why a TH350? CJ7 's came with the GM Turbo 400 . Both good transmissions, but the GM Turbo 400 is usually considered a stronger Transmission . The TH350 though is shorter in length.
Nice work... Glad I found this build. I like your dash work. I'm supposed to be getting ready to put my front axle back together but spent this week ordering parts off eBay, including some parts for my dash that I won't need for months... lol.
mocked up the transfer case and as I figured all the cleareances were gonna be tight. Garage tip for ya' if you are working on installing transfer cases use some line bolts to help hold that weight up until you can a bolt started. Tip 2 use a milk crate(or similar) to get the weight up closer to the transmission, so you don't have to lift off the floor.
New/different header on pass side.
Getting near the installation of the TC. What is a line bolt ? You have a picture? Thanks. Thinking about a a little different tip 2 but will keep yours in mind
