4.0 Head, MPFI, and Serpentine on my 82 258
ThisGuyUKnow
Full Time Jeeper
- Featured
- 7
- Harleysville, PA
- 1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
I am still having woEs with the darned fuel pump circuit. Everything seems to be in place and I have isolated the wire that is supposed to power the pump but the problem is when the key is turned on it only goes hot for a split second and then something( assuming the ECM) shuts down the circuit. It should run for a few seconds when he key is turned to on in order to primethe line with pressure. I posted in the 4.0 tech section of cjoffroad and some said I need to wire in the fuel pump resitor ballast and the fuel pump resister ballast bypass. Makes sense but they weren't with the harness I bought and I can"t find any snipped wires that might wire into these ballasts so
I may for the time being just run a "run" hot line to the pump and bypass the computer control for the pump but man I really wanted all the systems to run through the Cherokee harness and PDC
