4.0 Swap w/Pictures
4.0 Swap w/Pictures
I wouldn't worry about the corrosion on the gears. It doesn't look like it's on the contact area at all on the second to last photo.
Surface rust is not an issue. Check for pitting and if you see that then consider replacing the offending gear.
Room to spare I'd say!
It was a litte tough getting that vacuum line for the pcv in, it almost touches the cylinder on the HB
Progressing nicely! You'll have mud on it by July. I think that tube you cut off the timing cover is just to hold a TDC probe for an engine analyzer.
Why are you mounting your air box on the right side? It looks like it will be in the way of the oil filter and the dissy. Is there not room for it in the front left corner where you could get fresh air to it.
The next two pics are of the PDC mount I will be using. It came from a YJ and originally Mount in two spots to the tray and one to the fender. i drilled a hole in the cj battery tray to ad a bolt and then used the existing bolt for the lower strut to mount it.
I tried that approach as well, but didn't want to move the CJ jack from its original location on the right inner fender....keeping the whole stock vibe. The side of the tray is Limited too with the wiring and heater hoses...
..... so I think the TJ breather will be a nice touch.. When I get everything installed I will need to create a custom bracket to mount the filter housing.. I need to wait until last because I still need to run coolant hoses and ac hoses and I need to be absolutely sure that the mount accounts for the needed clearances.
Let me know if you get that bracket figured out because the bottom of that box is a nightmare of uneven surfaces. I'm mounting the YJ AC dryer on the indent of the right inner fender by the grill and with the air box, jack, and PDC/ wiring....its a tight grab for real estate. My heater hoses turn inward from the firewall and run down the engine with a special bracket from an XJ I think.
I tried that approach as well, but didn't want to move the CJ jack from its original location on the right inner fender....keeping the whole stock vibe. The side of the tray is limited too with the wiring and heater hoses...
Ed, I'm closely following your build on the the stroker, and using your work as a guide. I haven't mounted the air box yet and won't until I've gotten everything else in. I don't think the pdc where it is will interfere with the Jack, but I only have the Jack mount because the p.o. didn't include the Jack with the sale( cough cough ;-)) this weekend it's on to making the harness and getting the tranny mount measurements
This is a stock breather for a tj they were not plumbed into the grill like in your cj stock. The air on the passenger side fender, close to the grill where this will pull air, is not directly heated by the exhaust and the hear from the radiator should have little too no effect. It's as good a place as any to get air from, I think,
Unless you are a wiring genius like yourself.;)
This will be a good example of the harnesses I offer to build for people in the classifieds.
As usual almost everything will run though the harness, with the exception being the sensor wires , heater blower, etc.
I have bypassed the headlamp switch and put the relays and fuse in the pdc. This isn't as heavy duty as jimbos bypass relay setup but it will work for now. I utilized the oem wiring which is about 14 ga. I checked it for resistance and found it to be pretty low so I felt I did not need to replace the wiring in the grill. The wiring should be able to handle stock to slightly higher out put lamps. I will be using some kc h4 light housings with 55/60 watt bulbs. Math puts that high output to 10 amps at 12v and 8.5 @ 14v.
Later I might try the ipf fatboys sold at quadratec. Those are 80/60 watt so about 13.3 amps @12v and 11.4@14v.
IPF 4X41 - IPF Fatboy II Super Clear H4 Bulbs - Quadratec
I'd say the circuit can handle 20 amps so the fanboy
bulbs would probably be the highest wattage lamps I'd put in that circuit.
After the headlamp bypass was done and the harness was thinned out, I was left with 3 extra maxi fuses in pdc to use for stuff. One with be the fuse for my flexilite fan controller, another will supply power for my heated seat pads I had them sneak in when I had the seats upholstered, the third will remain unused for now.
With the stock breather / box on my XJ, the air filter showed evidence that air was pulling through one half of it stronger than the other. In essence, once one side was dirty, you could turn it and use the other side... Once I saw this I modified the box somehow to pull evenly across the filter and get better flow but I don't remember what I did. I also swapped out the exhaust header with a better one that still looked stock. With both of these simple changes the power and mpg really improved especially around the Rockies while I lived there.
Wish I had looked into the injectors like you are going to install. Wondering what that would have done. :cool:
That's interesting on the breather, we will just have to see.
