4.0 Swap w/Pictures
4.0 Swap w/Pictures
Does the top part of the shifter have to be in that position or can it be turned 90 degrees?
Yes it can be but I'm pretty sure it will still hit the console. Also the shifter will bend towards the dash then.
Gonna be up and running by July 4th weekend?
I know this isn't exactly what you want, but how about putting some slight bends in it so it looks more like a T-5 shifter?
I know this isn't exactly what you want, but how about putting some slight bends in it so it looks more like a T5 shifter?
Matt,
I've already enlisted you to fix up my custom yj shackles, I think you just enlisted yourself to modify my shifter. :D
I'm thinking we remove the 3550 shifter from the center hub and weld a T-5 shifter in its place so that the welded side faces the dash. Should clear the console and look very stock.
Congrats Man , glad to hear you got her up and running. The 4th of July is still awhile away. ;)
Congrats on bringing it back to life I'm sure you will have it on the road in no time and a big thank you from someone who has plans to put a 4.0 in mine I have learned alot from your build. :chug:
Want me to make you a 4.0 harness?
No I have been thinking about this for a long time and what I'm thinking is buying a Yj with a 4.0 and cannibalizing it. My tub is shot so buy buying a YJ I can use the tub and the 4.0 with all the wiring and Transmission because I have the T-5 and then I get the YJ brake booster and all that goes with it. It seams to me like a cheaper way to go I get everything to upgrade my Jeep and can sell everything I don't need to recoup what I spent on the YJ. I think it would be way cheaper than to try and buy all the parts separately. And I don't think the world will miss a YJ :D
No I have been thinking about this for a long time and what I'm thinking is buying a Yj with a 4.0 and cannibalizing it. My tub is shot so buy buying a YJ I can use the tub and the 4.0 with all the wiring and trans because I have the T-5 and then I get the YJ brake booster and all that goes with it. It seams to me like a cheaper way to go I get everything to upgrade my Jeep and can sell everything I don't need to recoup what I spent on the YJ. I think it would be way cheaper than to try and buy all the parts separately. And I don't think the world will miss a YJ :D
If your going through all that trouble ditch the T-5 for an ax15. If you get the right yj that will already be in it.
Ha, didn't I say it sounded like you were one tooth off!
Glad you got it .
If you plan on using the T-5 boot, watch for isolator clearance
Glad you got it .
If you plan on using the T5 boot, watch for isolator clearance
Are you glad? I am pretty certain you hired a voodoo shaman in New Orleans to curse the Jeep when I bought it from you! I'm guessing you were really ticked I wouldnt let you take it apart and paint it blue with a white top!:cool:
Or did you just curse the 360 because I wouldnt let you drop in a AMC 258 i6 / 4.2l ?
Very nice write up so far. I subscribed so i can follow every post. Keep up the good work.
Me too. Very well written.
Sent from my GT-I9152 using Tapatalk
