Doing a Ax15,and YJ Booster Swap
ThisGuyUKnow
Full Time Jeeper
- Featured
- 6
- Harleysville, PA
- 1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
Great job!
Thanks i just did a lot of research and no one really documented it in complete detail so I just posted up what I would have liked to have seen when I was first researching this swap. I think what most people should know this is not as cheap as you think. I thought man I can get a new Ax15 for 200 bucks and put it in and new drive shafts ladeeda. Well you have to get a Hydraulic clutch which new is 165 and sometimes they come with the tranny sometimes not, then there is the flywheel, clutch, AA clocking ring and Input housing(I still think that you might be able to resell the clocking ring and just use the new input housing and redrill the tail housing to match the stock clocking), the list goes on. Its definitely making me consider future swaps I have planned as the cascading affect down the rest of the vehicle really surprised me and caught me compeletely off guard.You have done an excellent job of documenting your trans change and we really appreciate it!Great job!
I figure since I already know my Exhaust manifold is warped that now I am just going to go ahead and go straight into the next project, 4.0 head, 4.0 exhaust header, AMC 258 i6 / 4.2l intake/carb, Which then will inevitably lead into my next project :4.0 InjectionI have decided I am unhappy with the extra acess plate on the right I made to clear the body of the front axle's shifter. I want to pull the carpet again and instead of using rubber to seal the area around the trow I want to weld a raised plate. I am paranoid that the way it is the rubber arm floaty is going to give up the ghost and I am going to have the elements funneling through the hole.
