4.2 or 4.0
It seems simpler to use the complete 4.0 since everything is coming out already, your opinion?
I see some doing the FI conversion with the 4.2 short block and 4.0 head, good or bad?
Why do you feel that is the best way to go (4.2 with 4.0 head)?
Did you use the electronics that match the head?
I will need to smog it here in our wonderful golden state but as long as I get everything from one doner vehicle it shouldn't be to bad.
Is there a preffered year? why?
me too as far as a Californian.
Does the 4.0 have inherent smog problems? or do they pass easily. I am also considering a 4.3 Vortec conversion. I am fairly impressed by the V-6 Engines.
Double the fuel consumption? if that is true and the system almost $3,000.00 for the system. I would rather make an engine swap.After spending a summer with the Mopar MPI on my 4.2 I would do it exactly the same way again. I have been to Death Valley at -250' up to 10,200' in the Big Pine Ca. valley and it starts and runs flawlessly allways as well as the fuel consumption is approx. double what it was.
I to am from the great state of California. Wouldn't live anywhere else. I talked to my smog mechanic because my 4.2 is getting real old, and he said the easiest as far as smog goes is to replace the 4.2 with the 4.0 as long as the donor meets the California emissions. The 4.0 being a newer motor would not be a problem as far as smog goes. He said it causes more heartburn when you try to change out parts. That just makes it harder to check and raises flags. I have my eye on a donor already but mine is still running good enough to try the Rubicon again next month. If it holds up I may just leave it until I can't go anymore. The more stock it is the easier it is to work on and get parts. My opinion anyway.
Tommy
