4 Speed issue
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
Let me search that one out a little bit. Rob had'em at Willy's Works. I just bought the joints as I did before, with a saw, a thread die and a drill it's fairly easy to do with just the parts. One thing for sure, the linkage metal is VERY hard. Without a little care you can easily destroy a thread die. I'll be back to you, that is if I can actually find them on line.
Edit #1: Here's a quick link:
http://www.quadratec.com/Assets/Installation/122837.pdf
It's not for a stock CJ but if you look at it you will see what needs to be done.
Edit #2: While looking these up I was reminded why the '75 needed work. The stock joints were loose and tended to pop out of their sockets. I imagine healthy joints would be just about as smooth as the Heim units are. Heim joints won't pop out though.
