4WD Low jumps out of gear in Dana 20
cgeorge5150
Atascadero, CA
1975 CJ5 - 2 in body lift, 258 L6, T-18, Dana/spicer 20, Dana 30 in front, Dana 44 with Detroit EZ Locker in rear, 4:56, Holly 4 BBL, 33's
2000 Silverado Z-71, 5.3L, 6 inch suspension lift, Chipped, 33's
2006 Suburban (family car means no real mods)
I took my '75 CJ5 out last Sunday climbing and crawling, during ascents I would find that the 4WD Low would jump out of gear multiple times, and though it is not marked it would go into a "2 Low" (The Transfer knob is 4 HI, 2 HI, N, and 4 LO)... But Jeep was definitely in 2WD, and if I shifted it up one, I was in neutral. A) Is this common or did PO do something I was not informed of. B) what do I need to remedy the jumping out of 4 Low. I will check the linkage, but if that doesn't fix the problem I was thinking of replacing the interlock springs. Any other ideas or places to find the springs, or will I need an entire rebuild kit? Best places to purchase parts?
are the two clips between the twin sticks there they look kind of like this with a slight curve in them to make them apply tension between the shifters holding them in place
the pins are located right above the floor pan between shifters as marked in red in diagram
It is not a twin stick
I run a bungie cord to hold them in place.
So one month later thought I would give an update. I put the TeraLow gears in, and the old gears showed signs of wear but not enough to really knock it out of gear. Finally discovered that the shift rod on the Transfer Case is being bumped by the body lift... Still occuring, so plan is to bend the rail and give a little more space between the two. Anybody have a better idea?
TCase Dana 20
