<div class="bbWrapper"><blockquote data-attributes="member: 397" data-quote="Old Dog" data-source="post: 455863"
class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
<div class="bbCodeBlock-title">
<a href="/community/goto/post?id=455863"
class="bbCodeBlock-sourceJump"
rel="nofollow"
data-xf-click="attribution"
data-content-selector="#post-455863">Old Dog said:</a>
</div>
<div class="bbCodeBlock-content">
<div class="bbCodeBlock-expandContent js-expandContent ">
The shim pack would stay the same with new bearings as long as you didn't change the ring & pinion. All the shop would be doing is pressing the bearings off and on, as long as you took it apart. Not that hard of a job to pull the carrier & ring gear.<br />
If you look for a different axle assembly you will have to look for one with the same gear ratio and than it might need to be rebuilt.
</div>
<div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0"><span style="color:orange">Click to expand...</span></a></div>
</div>
</blockquote> <br />
<img src="/community/data/assets/smilies/agree2.png" class="smilie" loading="lazy" alt=":agree:" title="agree :agree:" data-shortname=":agree:" />With that particular problem, its going to be expensive. One might even call it catastrophic failure.<br />
<br />
I wouldn't try and cheap out on any repair you choose. It's easy to spend other people's money, but axles aren't cheap. As IO said, you don't what to know what he has spent on that axle.:drool:<br />
The absolute cheapest part to this repair will be the root cause, the bearing. If it takes you some time to collect the funds, I would wait and have it done since you expressed concern for doing it yourself. Getting another and having it re-geared and all will cost WAY MORE than getting yours fixed.</div>
