'76 CJ7 how to tell?
Germalicious
Fernley
'76 CJ7
I'm trying to find multiple or easy ways to tell if my '76 CJ7 has the part-time conversion kit to 2x4 installed. Or if someone I guess did the cheap route and just installed manual locking hubs to eliminate 4x4 full time.
I'm not too experienced with the emergency drive vacuum actuated 4 wheel drive switch, and the warn manual locking hubs.
How would I start to go about putting it into 4wd first, should I flip the switch and then get out to lock hubs, or vice versa? Is it bad to do one or the other, as well as disengaging? Older style Jeeps are fairly new to me, so I'd like to learn before ruining something I could have prevented.
Thank you!
This should be a 'sticky'. :notworthy:
Which tranny oil are you revering to? Ford type ATF or Dex/Merc?
This was REALLY informative. Thank you. I'm going to attempt to see if the kit is installed as well as check the chain in the t-case for the slack. I've got two questions regarding this.
1.) I do have the low range option on the floor, towards the gas would be H, middle N and towards the rear L? It does feel a little wonky and hard to tell what it would be in by the lever though. (it's a tiny lever, and rubs against the body) Should that be all the way forward for everyday use, and then all the way back towards the rear for climbing and what not? And assuming the neutral is for towing?
2.) Also, say the part time conversion kit IS installed, if the switch for the emergency drive was on the 2wd setting, and I had the hubs locked and then drove the vehicle, what would be the outcome of that? As well as vice versa, hubs unlocked, yet the switch in 4wd, would it just not work, or could that damage parts?
Sorry if my questions don't make sense, trying to make them as simple as possible.
Thanks!
1) All the way forward for everyday use. That is the low range is not engaged. If you engage it try not to drive over 35 mph. Neutral will allow you to tow with all 4 wheels on the ground just make sure your in 2wd also. You'll need to keep an eye on the heat build up in the Transfer Case . Shouldn't be a problem, at this point the Jeep is like everyday driving.
2)Hubs locked in 2wd is not a big problem, but you have all of the front drive train rotating, just without power. 4wd and hubs not locked is bad. You are trying to put power to the front wheels but they are not engaged. This puts undo stress on the front components.
Let us know what you find, please.
To the OP - if you're new to these things, there's a lot of inaccurate information out there on the QuadraTrac / GM Turbo 400 combo; so please ask any questions you might have (like you have done so far).
This bad information is written by those who either don't know how to use the QuadraTrac correctly or maintain it correctly or both. Properly used and maintained, this is an excellent setup that's rated for 3/4 ton use.
As I've stated in other QuadraTrac related threads, there are a lot of good driveline setups available to use, this is just one of them.
I understand that-But there are 2 different types of ATF out there. Which is the best choice?
Sorry, wasn't paying attention. I think the Dex/Merc would be a good choice, since that also is recommended for the GM Turbo 400 .
