77 CJ5 304 overheating problems continue
winecountryjeep
40k Miles,
12 year old rad
New water pump (and yes its pushing water the correct way)
New thermostat (fail-safe 180F)
New rad cap (16lbs)
Bottom rad hose not collapsing
Goes from cold to almost hot in under 5 min at idle.
Coolant does not seem to be flowing, because the rad top return hose is cool to the touch and seems to be full of air.
No expansion tank. I ordered one, but it hasn’t had one for decades and there hasn’t been an issue until recently so I do not think it’s the issue.
Where do I look next? I’m at a loss.
12 year old rad
New rad cap (16lbs)
After rebuilding the engine, it overheated within just a few minutes. After trying everything else, I drilled a small hole in the thermostat to allow air to purge. The engine has run at normal temp ever since.
