79, 304 cooling problems
Hello All, I’m new to the site & not computer expert.
I am having cooling problems w/AMC 304 amc engine on a 79 CJ5 SA mostly original. Any help will be appreciated.
Rad. cap 16 lds, new rad., new hoses, original water pump & it’s turning & flowing good, checked thermostat & opening at 195 degrees, 4 blade fan w/ no fan clutch, have fan shroud. Installed a VDO temp gauge & sender. Wire running from sender straight to gauge. 45 mph runs right at 195 to 200 degrees. Run up to 60 or higher mph engine runs approximately 210 to 215 guess. Needle doesn’t go pass the second 0 on 200 number. Hope you understand that. Have flushed out block & heater core & rad. 3 to 4 times. What am I missing?
