'79 304V8 Vacuum / Air Lines
GravyProv1
Hopkinsville, Ky
1979 CJ7. 304V8, AMC20 Rear, Dana30 Front, T150, Dana20 xfer. 2.5" ProComp Lift. Fiberglass everything.
'79 304V8 - Anyone have a simple diagram that shows the bare minimum Vacuum / Air Lines needed for the motor to run properly.
All of the emissions lines/hardware/pump items have already been removed. Exhaust manifold has also been plugged.
Line from distributor to carb is still connected.
Thanks guys.
The bare minimum would be the one to the dissy and one to your PCV and brakes if you have power.
I noticed on the bottom of that drawing that it says Auto Transmission . I assume that's automatic transmission? Is it the same for a manual? That being said, I don't have an EGR, CTO, NLVR, air pump or purge canister and am still trying to figure out what all I should keep and what I should seal off.
No it is not them same as an manual Transmission . The vac is for the kick down on a auto trans.
New question for this area.
My buddy says I should still have a vapor canister for the fuel tank. To keep this simple, what's the best way to add vapor canister. Also do I need to incorporate some sort of valve or switch for purge?
Thanks.
    Best for votes
    on specific items
$45.00
  22.5%
