Build Thread 79 CJ7 "They’re coming to take me away aha"
Since I only have a bottom and a top hole the bottom will have to do double duty as a filler and drain. Air "out" will be on top.
Back to Mr bass's build, thank you Mr. Bass
No problem, glad to help. :D
Wow. Another awesome piece of work. Well done!
Nicely done, THX for the pictures and details.
Well done Bass and OJL
Last year you guys made it to Colorado. This year your prepared. Lots of nice solid well thought out tweaks that should make a big difference this year. Cant wait to hear how it all works out. :chug:
We are having some electrical problems. The strange kind....
The E brake releases with such force, it's causing the fuse box to lose connections internally. (we think...) Last week we lost the dash lights and I made a work around with an external fuse. I had hoped that was a fluke, but no, no it's not. Today when releasing the E brake one of the flasher relays fell out :eek: , plugged that back in and those work but now the connection where I tapped ignition power for the relays for the on board air, and the new electric pusher fan have no power. There is voltage on both sides of the fuse (with the ignition on), but no voltage at the adjacent connector just like the the fuse for the dash lights. I fear our fuse box is failing. What could be next?? The relay power for the elockers during some up hill climb?? :eek::eek: We may have to replace the fuse box depending on what we find. We will pull it apart tomorrow. Seems I spend a lot of time upside down in our jeep parked in the shop. :rolleyes: :bang::bang::oops:
We will probably have to remove the front seats and seat brackets, and that dang speaker that took forever to get in after installing the full cage. I can hardly wait... :rolleyes::rolleyes:
Put some dielectric grease on the fuse's 'legs' or contact points if it a tube fuse.
A rolling stone gathers no moss......
x2 on the aluminum intake
Save about 60 pounds, and more air flow.
Make sure you check the intake before installing
I use a straight edge and feeler gauge.
I'm willing to bet the driver side is straight and the passenger side has some daylight.
Should be good if under .008
Like the spring compressor
Good team work! :chug:
:D
With the money that we saved, I just ordered the new clutch assembly!
That was one heck of a post just to see if I was still paying attention lol. I am , probably more now than ever. My 79 got here Sunday and my build is going to be eerily similar to yours. I'm guessing you never checked the compression before on the AMC 304 ? Crazy the things you find working on these old Jeeps.
That was one heck of a post just to see if I was still paying attention lol. I am , probably more now than ever. My 79 got here Sunday and my build is going to be eerily similar to yours. I'm guessing you never checked the compression before on the 304? Crazy the things you find working on these old Jeeps.
Don't we all know it! But seriously, I wouldn't wish anything "similar" on anyone after what we have been through!
