Build Thread 79 CJ7 "They’re coming to take me away aha"
This entire thread should become a 'sticky' !:punk:
Great job! :notworthy: You'll like the York Compressor. :D
:notworthy:
Another modification I must make. Looks great. :chug:
I'm pretty sure the bronco site you have has a part number for the intake air filter.
:rock:
YES-On use'n a relay for this setup.
Spray bottle of very soapy water will locate those leaks.
It's 16% RH here at 86*. :poke:
Duffer posted all the part numbers in another thread I started so the part number is already in my files. I just don't know if it's worth fabricating one by hand for what they cost!
:rock:
16%??!! even I could take 86° at that kind of humidity.
I'm on my way out to the shop in spite of what I said, the wife kind of got me off my butt! :eek:
I hate to be "that guy". Are you at all worried about knocking the gauge assembly off? I know if it were me it would only be a matter of time.
With your compressor cycling the way it was, I can't help but wonder, could your check valve be backwards?
Did you not have enough room in front of your fuel tank to mount the pressure tank?
87* @ 15%
It's 13% @ 89* now. :D
87* @ 15%
Check valve is in correctly. In my opinion, the compressor just puts out too much air to be restricted down to a 3/8" line that close to the compressor. It would fill the fittings and filter faster than the air could flow all the way back to the tank, and the limit switch would kick out. Kind of like a water logged well pressure tank will do. As soon as I installed the manifold (roughly 24 cu,in.) and went to larger fittings, the cycling cut back to one time to fill the tank. I can live with that, I'm not going to run 1/2" hose all the way back to the pressure tank just to avoid one cycle of the compressor. The tank is about 2 1/4 gallons, and takes about 20 seconds to fill at an idle. That's good enough for us, and it keeps the oil blow by at a minimum.
No room in front of the fuel tank. Earlier in the thread I talked about the PO using a T-18 from a 1978 J series truck without short shafting it. So we still have the 5" spacer between the bell and tranny. With everything moved back 5", the drive shaft is probably shorter than a CJ5 . Too close for comfort when wheeling!:eek:
Time will tell if the location of the gauge is a bad decision!:rolleyes:
You can also close off the compressor's inlet some, to reduce the volume of incoming air.
93* @ 11%
I've been following this thread but somehow didn't notice the part about having a long T-18 . Could I get some advice from you? ....... My plan is to use only one air line going to the tank, I figure the line that fills the tank can supply air as well. Is there a flaw in the plan to use only on line? .... Just a thought, could your tank fit under the seat between the side and the frame rails?
I've been following this thread but somehow didn't notice the part about having a long T-18. Could I get some advice from you? ....... My plan is to use only one air line going to the tank, I figure the line that fills the tank can supply air as well. Is there a flaw in the plan to use only on line? .... Just a thought, could your tank fit under the seat between the side and the frame rails?
I'm confused...
Not sure how you could use the same hose that supplies air to the tank as your work hose without disconnecting it to use it then reconnecting it to refill the tank, unless you are asking if you could just tee into the same line that supplies the tank with your work line. That would work, but you would get pulsating air from the compressor since the air tank is in essence only "floating" on the system instead of being the air reservoir. This is no problem for filling tires, but does weird things to air tools. I only have one hose going to the tank, then a separate one on the other side of the tank for filling tires, etc.
I considered mounting the tank between the frame rail and the outer body, but I have rubbed rocks with the thick diamond plate that currently serves as the rock sliders, and the tank would be below this level. At some point in the future I may rework, and use the bumper as the air tank. That will give us back a little more space inside the Jeep.
Yeah, the manifold would act as a Tee in the line. I'm really attempting to reduce the number of air lines running around on the CJ. Then there is the other side of it, longer and larger air lines essentially makes for a bigger tank/air supply. ..... I just tested the threads on my drain, they are standard 1/4" NPT threads so the addition of a tee fitting with the drain and the air in would work. Air in what is essentially a surge tank with smooth air coming out.
That should work. The manifold kind of acts like a water hammer preventer does in your household plumbing.
Take your 'working' air from the top of the tank, and leave the bottom as a drain.
