79 engine wiring diagram
Jimbos76cj
Full Time Jeeper
St.Cloud FL
83 CJ-7.. 4" YJ springs front rear, J-10 44 front/AMC 20 rear,6 cy auto dana 300 35' bfg Done and gone!!
Ask me about my head light upgrade harness!!!
I'm tryig to find a better wiring diagram for my CJ harness.. Title says it's a 80 but the harness wire in the harness don't match up to an 80 but are almost exact to a 79 so I'm guessing it was produced in 79 with a 80 build tag.
So is my issue.. For what ever reason I like to redo wiring harnesses.. I really like a challenge. Well the wiring harness I have for my project is chopped up bad for the engine side. Under dash and lights are all solid but engine side is cut down to about 6" I don't want to buy a pre made kit and waste a ton of money. I've been all over google and as many CJ forums as I can find but they all have the same diagram with the same problems. Either I can't read a few wire or they are printed poorly. Every pic seems to have the same issue even in the book and FSM same problem here's the one I'm talking about
Jeep CJ Wiring Diagram - Jeep Year 1979
Does any one know of a different or better diagram?
I found this one :chug:
I actually had no issue reading the one you posted..it was very clear.
If it helps... I just finished rewiring my AMC 304 CJ7 engine bay. i can assist with pictures if you like.
Does yours have the motorcraft style ignition?
I have several diagrams that I combined to make mine work.
