Build Thread 83 CJ7 its time to get it done
Nice progress!!
You might wanna take a look at the welder and compressor - I’ve heard some of them have plugs that will allow swapping either one into an outlet allowing the compressor to refill. Yours may be different but it’s worth a shot....... [emoji6]
Nice progress!!
I have my compressor hard wired to a disconnect and a shutoff valve for the air, I leave it on all the time with my Regulator and hoses depressurized
Well that was fun...holes done...checked measurements thanks gert..been a useful day of finishing :dung:ty jobs....
Well that was fun...holes done...checked measurements thanks gert..been a useful day of finishing poopiety jobs....
Nice progress on yours as well, a buddy of mine years ago used easy off oven cleaner as a paint stripper worked great might help on your small. Parts
I wasn't in any hurry, but I just got done striping some parts of paint with some brake fluid. Worked pretty good.
Nice!!
Never heard of a CJ with a track bar, hell... I didn’t even know what it did until I just looked it up.
Thanks for helping me learn something new. How would I determine if I even needed one?
Spring over suspensions flex leaf springs more, V8s flex leaf springs more and lead foots flex them more....
I have all the above lol
I would not worry about one unless you have a spring over like me
Sent from my couch using Tapatalk
You’ll need it if you drive like a knucklehead [emoji6]
Yep that was me when I first did my V8 swap lol
Sooooo... I’m putting in Chevy 350. While I’ve got the thing down to the frame would it be a good idea? Sorry to hi-jack the build thread Gert, this track bar discussion is new to me.
I'm thinking you do cross over into the twilight zone until you get to a 360. :)
Spring over? Spring under? Stock springs? Aftermarket left springs?
Looking at your pinion angle whats it set at?
Ya I dropped the skid plate after I set the spring perches on the axle so I need a little more shim to set the angle back inline with the driveshaft......
Poop I just realized I have the shims on backwards
Spring under and I am replacing the stock springs with OME YJ since everything I’ve read about that upgrade is that it’s well worth it.
I would not worry about a trac bar then if I where you
Sounds good. Less to worry about during the rebuild. Appreciate the advice.
$125.00
  62.5%
