Build Thread 83 CJ7 its time to get it done
LMAO [emoji23] [emoji23]
He can use it to wash his mouth out if it’s still there come Spring time [emoji6]
LMAO yep if it’s still stuck in the garage come spring I will need something to wash my mouth out
I really don't think you will need that when it's stuck sitting in a garage. :)
You have a point. He's just sitting inside drinking beer and whistling Dixie. At least that's what the pictures are showing to me
Oh, man - Tough crowd....
LMAO
Sent from the first of several Holiday Overeaters Anonymous gatherings using tapatalk...
Don't worry ! He has something to work toward. Moab & Colorado
Whew killin me Belizean yer killin me
Just a little motivation so you can get wheeling on those trips !
I’m definitely motivated, should have rear driveshaft installed shortly
Great ! I know you are to get yours wheeling.
Just saw the ford, care to share details on the find?
And good progress on your Jeep build.
Grandmother in-laws 1917-22 touring car, she said the last time they drive it was in the towns Christmas parade and they drove it into the barn and has been there since, it sank pretty far into the mud, the whole rear axle and driveshaft tube were covered, all four wheel hubs were buried, I have it sitting on wood 4x4s for now to keep it above ground, all the upholstery is gone and so is the coils for the motor, speaking of which it still turns over as free as can be
Boy I sure was excited to be welding right now but I forgot to grab the gas line and regulator for the welder grrrrrr
Did you rough the plastic up before you fiberglassed it?
Did you rough the plastic up when you fiberglassed it?
You bet, roughed it up with sand paper cleaned it with window cleaner to get the mud and grease off then put a layer of epoxy down before I put the cloth on followed with a layer of epoxy over the top to soak the cloth real good
Going to wait on this to cure to see if I think I need another layer of cloth for strength
That's what i was wondering looks good. Ive used that fiberglass kit made by bondo not a bad kit for little projects.
It is a good one. I used it on my fan shroud
$20.00
  10.0%
