Build Thread 83 CJ7 its time to get it done
- Featured
- 3
- Media
- 71
- Resources
- 2
- Rockwall,TX
- 1983 cj7, 1971 Dart, 1942 Willys slat grill
Getting closer by the day..... 216 days til Colorado that’s my goal I really want to be there this year so I sat down and practiced some more basic lathe skills and found out that our lathe is so wore out that to achieve a three place decimal measurement I need to use a dial indicator I made a spacer for the axle to center my brake rotor and wheel, found out during this that Moser has already pressed a hub spacer on the axle so I am going to pop that off some how and replace it with the one I made. The center hub is 2.75 the rotor opening is 3.75 x .35 deep and finally the wheel opening is AMC 258 i6 / 4.2l inches. I used an old stainless pump flange from the recycle dumpster. I realized after I was done milling it up that there is nothing holding it in place since I did not make it a press fit....... so I have decided to just drill and tap it for some screws so I can keep it attached to my Jeep going down the highway
