It’s cold outside so let’s see how long this flys before the wife blows up lol
I wouldn't worry about it gert. You could probably put that Transmission back together on the kitchen table too. Snicker-snicker-snicker.
How do you like that plastic glove box? Ive been looking at them my stock one is in awesome shape but think a plastic one would be better.
I like the plastic one for everyday use, I don’t need to worry about it getting wet or how much weight I put in it, I say the stock one is good for a restoration
This should be enough spare wiring to get my dash wiring straightened out lol, should also be enough to really get caveman scared
I'm scared just looking at that mess.
Got a little carried away cleaning up my wire harness and painted my dashboard
Sent from the wifes kitchen :) using Tapatalk
I've had my plastic glovebox for 30 years. Works great
Ive been thinking real hard about ordering one but dang my jeep is going to be new by the time im done replacing stuff I see want to change.
And the problem is?????? LOL
Just means it’ll live forever
Got a chance to take the little ones to the Good of the Land festival and see some YouTube stars, then there was a car show at the Lowe’s next door
I thought I lost this years ago
Now if only I could find the rest of my alternator bracket and headlight switch
Looks like a Dana gasket.
Yep 2 Dana 44 gaskets but what’s sitting on top of them is the fresh air adapter that bolts to the coal to route fresh air the the air cleaner
Well I finally found a use for an 11mm socket lol
I use 11 mm all the time pretty much the same size as a 7/16 socket. But thats a good idea to take those nuts out on your switches
Very nice!! Just stole that idea [emoji16]
Not as far as I would like as usual but further than I was, sure was glad when my screw driver slipped that I had painted with krylon lol touch up will be much easier
Sent from my kitchen using Tapatalk
Well, I see you had to move your dash back to the garage........ the sock diversion ploy didn’t work, huh?
