    Thank you for your support!
It’s been a lot of years since I’ve used this meter hope it still works
Sent from my kitchen using Tapatalk
Is that a wide band or narrow band AFR gauge?
While searching for the O2 meter I came across a box of car books..... bringing back memories
Put ya some LED bulbs in that fluorescent fixture and it'll light up your world - those things are stupid bright.
Sent from the first of several Holiday Overeaters Anonymous gatherings using tapatalk...
I bought the fixture at the Depot. Are the LEDs there also ? I don't get out much and have never looked for them :)
Yes they are, also check out amazon
Some of the bulbs will require the bypassing of the ballast
Sent from my secret happy place using Tapatalk
Thats one thing Ive always wanted to get into racing.
Ouch!!!
Haven’t found my old front shock towers yet but did find the source of my engine tap, for some reason cylinder 1 rockers were pushing on the valve spring retainers instead of the valve tips and wearing them out prematurely.... and of course I’m out of time to finish fixing that
At least it’s diagnosed
Got the tapping noise fixed and got my air fuel meter in just in time for it to start sprinkling again,
Hoping I got the valve cover leak fixed as well
Sent from the garage using Tapatalk
Accidentally set video to private on you tube
I just heard Homer Simpson.......
DOHHH.........
