Well success my new power steering hose holds 2800 psi that should be good enough
Added a second return fitting to my power steering reservoir also
Time
To head to the house and get a few things assembled
Something like this
Im waiting on an adapter fitting for the back of the pump so for now im going to run it with the old hose and start on the rock ram setup
Not blowing fluid all over the road so i will gladly take that win
Lol always something
At minimum it was a good Ryobi drill press while it lasted
I think i know how and where im mounting my ram at least
Ok, even Harbor Freight is smiling right now ...
Where’s the duct tape ?
Ive been waiting on the rain to stop for a few days now so i could get some things done
I still need to tidy up my spaghetti factory of hoses but i think she works pretty good
I scored a new rear axle for the tow pig this week to, im going to start adapting it today, a 2004 dodge 9.25 with 3.92 and a trac lok its 69.25 wide for $AMC 150 which looks to be the absolute widest i can go
This thing has massive 13.8 discs on it and 9/16 wheel studs
I seriously recommend this as a great axle for a Jeep, it super beefy, easy to build (threaded adjusters on the carrier bearings)no gear ratio break on the carrier, was in continuous production from 1968-2010 has a 3.5 inch diameter axle tube
Looks like it’s all coming together nicely.
I didn’t realize til i was looking through the beginning of my build thread looking for my shock part numbers that i bought my Goodyears in 2017 :0
And i forgot my rims are 9 inches wide so……
Well the Goodyears are off and up for sale
These 35-10.5s look so good on a CJ
9 inch rims are perfect width for these tires
Now im about to pull my Transfer Case and shim my front shifter rail spring and add a Novak pan
Hard to believe i put this t case together in 2010/11 and havent touched it since
I can’t recommend JB Conversions enough
I keep forgetting how heavy a Dana 300 is until you try to pull it out from under a jeep with both outputs trying to spin
I very lightly polished my front shifter rail and added 2 #6 washers under the spring
I find it easier to assemble the intermediate shaft with a dowel and tacky grease to hold the roller bearings in place as well as 2 1 1/4 dowels on the ends holding the washers in place
I finally got my Novak cover, maybe one day i can get that super short novak output
Im also wondering if i could just redrill the output on my Transmission or the input of my tcase and ditch the rotation ring…. That would make it almost 3 inches shorter
Do you really need the clocking ring…
3 weeks, 1 day, 8 hours, 12 minutes, 7 seconds
