85 CJ7 with auto hard time shifting out of park
powdertwoplanker
Hi all, Just got this 1985 CJ7
. Its going to be my DD. The PO said that its got a 4.2 out of an 89 YJ, but everything else is stock 85. SO after some research. I think I have the Chrysler TF-999 transmission. Jeep runs great and the only real problem so far is: ( I did do a search and didn’t see anything that helps. sorry if I missed it)
that it takes a good amount of force to shift it out of park
. When I do shift it I usually skip R and go right to N or D. I had the column apart to tighten it up (the tilt was loose) didn’t see anything wrong. I disconnected the cable the the column seems to move just fine. I notice that the cable is like 6 feet long and makes a couple of loops, Is that normal? The other problem is that I can not shift it down into 1st on the column.
So I’m thinking that the cable is just too long? But I can’t seem to find any info on what the cable length should be. Does anyone know? What else might cause this problem.
I'm going to look at the kick down stuff tomorrow, But she seems to do just fine shifting gear on its own. Just real hard coming out of park.
Thanks for the help in advance
). I keep you posted. PM me your email and I can send a bunch more pictures then too.
SO when I shift to park, I am in park.
