A few electric fan questions
I'm not sure twin fans are necessary that's alot of air besides most vehicles only have one cooling fan the second one is typically for AC. I'll try to get a pic this morning we've had 2 days of :dung: weather here
Sent from my E6810 using Tapatalk
I went with the twin fan set up for a ford contour. My understanding is that it is about maximizing the area of the radiator getting air pulled through it. The two fans and shroud for the countor fit the radiator of my CJ perfectly. One bigger fan would work, but I felt that the corners of the radiator would be too much area un-utilized. But then again, with the two fans, there is still unused areas. So ....... who knows. All I know is that the original single large fan worked. And now the twin smaller fans work as well.
+1...fits like a glove
This is the one I went with...lopped the plastic hooks off the sides with a cutoff wheel and fastened it with the pull-through jobbies that go through the fins:
https://www.rockauto.com/en/moreinfo.php?pk=7148432&cc=1413964&jsn=453
https://shop.advanceautoparts.com/p...XOiWxWYQ3lLdnsPlYJgaAic_EALw_wcB&gclsrc=aw.ds
Oh no worries, I understand. We've been having high winds here with a touch of snow dustings so nothing is getting done here either. My jeep is being used as an anchoring point for my car canopy, lol. I was thinking twin fan because as a friend of mine said you can wire one fan to come on at a lower temp and the other kicks on above a certain temp. I agree with you, normally I probably wouldn't need that much cooling, at least not where I'm at, but most of the jeep gatherings and trail runs are down in the valley (Phoenix area) and it gets pretty warm down there in the summer months. I don't want to take a chance on overheating.
I've read that the contour fan is what people were using but wrecking yards are scarce around here. There are a few twin fans in aluminium shrouds on ebay I was looking at that are "made for jeep" but I'm waiting to get word back on a radiator before I take the jump. Now that you mention it it does make sense about having more surface area for pass-through air with a twin setup. Less air blockage. I was thinking single or twin fan from just a cooling power standpoint.
I bought a new Dorman fan set up off of Amazon.
Been running it since December. Works great the relay kit I bought for the fan control was a bit hard to figure out as the instructions were clear as mud. But it's doable.
No fan and relay kit came from Amazon I included links in an earlier post
Mine fit no problem
That's fine. As you can see my wife's CJ7 is on the back burner waiting for time and money
I hear ya, which is why I'm on a tight budget, lol. My wife says no more money, lol.
    Best for votes
    on specific items
$35.00
  17.5%
