A tale of two carbureutors
Make sure you get a nice straight shot for the linkage cable from the carb to the standoff for the cable otherwise you'll get a sticky pedal.
Wooly
Good call - I'll pay attention to that.
I keep seeing where people say to just pull the coil out of the Carter electric choke unit and reverse it so that it moves the choke in the correct direction. does anyone have a good way to do this? the coil in mine doesn't seem to want to come loose. If I can't loosen it, I'll probably go manual for a while and get a new thermostat from Mike's parts or ebay later on.
almost done with the linkage, should be putting the carb on today! (yesterday got busy with Christmas stuff...)
May I suggest you get the linkage in order before you button everything up. there is a good chance you may want to do some welding/brazing to get things pointed in the direction you need and will move the plates 90*.
I have an electric choke on my 2100 that is not wired and does not have the stove pipe but it does a very good job of closing the choke when cold and opening when warm enough to run. You will need a working pull-off.
IO - so you use just the ambient air and engine temp to move the spring and it works okay for you?
Wooly
I couldn't resist, I bolted it on and cranked it up and it runs beautifully after I set the timing and tweaked the idle screws. Gonna put a vacuum gauge on it and dial in the carb a bit more, but it's almost there. I love the difference. Going to try and drive it but not until I get the linkage done. I think I'm going to do the straight back cable from a AMC 304 -powered CJ and call it good. I'll keep the bell crank and stuff though in case I need it. Thanks for all the help, I'll put photos up in a couple of days. You guys made this much easier! I'll report back the difference in driving once I know how it drives.
Wooly
so far so good, still a cold natured machine and I don't live in Brewer Maine. But it is closing and opening when I think it should. The electric part, when used, is wired to an oil pressure switch that starts to warm the coil when oil pressure is reached but it is still a thermostatic choke. just be sure to use the choke pull off or it may not want to open all the way.:chug:
Why the vacuum hose on the front of the v'cover? :confused:
That's what the PCV valve is for. ;)
No lumpy I think he has it right. The front is the air intake for the crank case, the rear is where it gets sucked back out with the PVC valve into the manifold.
On my 6cyl-front is for oil fill only.
If you pull'n a constant vacuum, as he is, the PCV cant/won't work.......:confused:
I have an oil fill in the valve cover, but the valve cover I have has two PCV grommets AND the oil fill.
The diagrams I keep finiding explain it as the hose in the front is fresh air in, which is drawn in because the PCV is sucking the crankcase air out. At least, I think that's what it's saying. The small hose isn't connected to a vac source.
OK-That makes since. It look'd like that hose was attached to the carb.:o
You do know that when engine does such in air(it does when you lift your foot off the throttle). If you don't have a breather filter installed. Your pull'n UNFILTERED/DIRTY air inside the engine.
That is why his breather line is behind or inside the air filter. A common thing inside air filter covers like his. I imagine the intake air is baffled in a way that allows it to travel through the engine before being sucked out. On an AMC V8 there is an intake air filter in the oil cap, most other V8's have one on/in the opposite valve cover from the PVC valve.
This is what mine looks like-
The PCV System
I ask'd about that front fitting/hose in post #50(bottom picture), as the picture shows the hose going inside the fitting and that isn't correct at all.:confused:
Ah, no, you're absolutely right. It should go over the nipple, but I haven't got the correct elbow yet. For now, it fits in there snug without pinching the hose. I'm picking up a new elbow today.
Yes-Baffled port is best.
