All kinds of questions...
TrebleHook
- Media
- 71
- Norfolk, VA
- 1979 CJ-7 with 1985 258/Ebay T-5/Dana 300 - twin sticks/AMC 20 Rear 3.73/Dana 30 Front 3.73/Alloy Wide Track Axles/2" Body Lift/Gremlins.....
More to follow....
Alright folks...this is why I joined...(to learn and to look a cool pics of CJs!!)
I just purchased a frame-off restored 1979 CJ7 with the AMC 258 i6 / 4.2l /T-4 /Dana 300 from a 1985.
Before I brought it home, the guy who did the restoration and PO (a very honest, skilled, and trustworthy Jeep lover, mechanic and machinist -- I saw his other projects and his shop-- total pro.) installed Wide-track axles with new one piece axles in the rear. Before bringing it home, I asked him to install a new polished aluminum valve cover and new seats front and rear. He did and the craftsmanship looks great and appears to be consistent with his general attention to detail.
If you can hang with me, there is more. When I first talked to the PO, he told me that it had a 3:10 "posi" rear end? I know that "posi" means posi-traction but I rarely hear it used with regards to Jeeps. I usually hear "lockers." The axle has a diff cover that looks like an AMC Dana 20 ...round and smooth. I presume its an AMC Dana 20. The PO also told me that once the new axles installed it would be a 4:10 (maybe 4:11?) rear end.
When doing the wide-track conversion, the PO also moved the front shock mounts. They are now more vertical than the original 1979. He claimed that they are now in the same place as a 1985 and that basically, the entire Jeep is functionally a 1985.
So I am a bit confused.
1. What rear-end do I have, and what is the explanation for its gearing?
2. After driving it on the highway the 100 miles home (it was winding pretty good just to do 55-60) it has 3 leaks. One looks like its the rear pinion seal. One is dripping from the skid plate. The other is dripping from the rear of the oil pan. The valve cover looks really good. Ideas?
I am in the military and have easy access to the "Hobby Shop" on base where I can throw the Jeep on a lift for $4/hour and borrow basically any tool I need while there. I am interested in doing as much work as I can...without screwing something up.
Oh, by the way...I need this to be a daily driver.
Thanks in advance! I'm looking forward to the lessons....
Cheers!
Dylan
Cheers!
Dylan
