AMC 20 Rebuild Woes
arrow115
Hello! First post. First Jeep.
I bought/rescued a project 1979 CJ7 with the goal of a full frame up restoration.
I am currently stuck on this AMC20 rear axle. I tore it down and replaced all of the seals and bearings. I rebuilt the drum breaks and when I mounted the rear tires, now the drivers side drum is rubbing on the shoes and brake backing plate. I have adjusted the end play with shims according to the service manual but still the drum rubs on the shoes and backing plate. I noticed whoever worked on it last put washers under the drum on the drivers side. I guess they were having same issue.
I am wondering if the hub or axle shaft is bent.
I am using the factory two piece axles. I am really considering the one piece axle conversion, but I was hoping to get this issue figured out before I spend more money.
Any help or advice would be very appreciated!
