AMC 20, Superior Axles, Need seals?
Bugs
- Apache Junction, Arizona
- #1~1983 CJ7, 4.2L, 5 Speed,3.5" lift, 33" PC,Hardtop Offenhauser intake, Holly 4 barrel, Header, D30 Front Detroit Lockers, AMC 20 rear with Superior Axles.
#2~1997 TJ 4.0L, Front/Rear ARB lockers.
I know Superior is no longer around, but I have Superior one piece axles in my AMC20 with a Detroit locker. I over filled the case after cleaning and changing the fluid and got leakage from the left side axle out the break drum. I over filled because I didn't notice the differential was tilted up for correct shaft connection due to the lift.
I filled about 25oz more than FSM states, waiting for it to ooze out the fill hole.... then I realized the hole was not at stock level.... Went out later and had a bigish puddle of axle fluid that leaked out the left axle.
I've read some that say its okay, just remove the excess, but I don't ant leakage when I have it sideways on the trail. So, I need new seals. Since Superior is no more, where and which seals do I order that will work with these axles?
Thanks!
Thanks!
if it is leaking it is leaking, replace it. becareful to not get grease/oil on brake pad or you will be replacing that to
