AMC 20 thrust block and Locker install help, info, experiance?
Goatboy4570
canada vancouver island
!983 CJ-7 258 locker moly axles 33's 4" lift MM hubs MSD/HEI 2100, 1990 YJ 258 31's.
78 Jimmy 357 Vortec 4 spd 205 lockers 33"s striped down, 63 F100 unicab 454 4spd RatRod, 87 S10, 88 S10 310V8, 87 Chev 3/4 ton, 80 Caprice Landu Coupe, 86 Monte 355 stock car, 1978 Monte 383 Vortec 4spd Slammed 10" rims Satin Black, 79 shovelhead OS chopper, 84 nighthawk, 88 CR500, 79xr500, 99 Susuki LTF500, 2010 Doudle bug 212 predetor. oya 2005 P71
The thrust block that is pinned between the axles in the centre of the spiders by the cross shaft, is it retained or disscarded with a locker install?
The instructions with my Lokka dont mention the block,
Is the thrust block cridical to the otter bearing preload?
You keep it unless you are installing 1 piece axles. And if you are not, you will be soon. Almost as sure as death and taxes.
Exactly right.
Most 'locker' installations are a carrier change. So, NO-You don't keep it.
BUT-With the maker your using. I would call them.
X2 on get'n 1 piece axles-Go with Moser. They are the BEST!
UPDATE-Just look'd at the LOKKA site, couldn't find a PN for the AMC mod 20 rear?????
