AMC 20 Welding tubes
driver007
- Canada
- 1981 cj5 304 v8, 300 Dana,model 30 Dana and model 20 AMC rear end
What seems to be working for welding the tubes to the diff housing? Four 1" welds. I have welded lots of mild but very little nodular cast. Pre heat to what temperature use a nickel rod like a 309 and post heat? Hate to mess up the only rear end I have. How do you check for sagg in the tubes. Would sagg really matter. Over time the rear end gets lots of stresses. Or do I just leave well enough alone? I do not plan on hard core driving just want to fix up while I change out the gears.
