Amc 20
Amc 20
driver007
Canada
1981 cj5 304 v8, 300 Dana,model 30 Dana and model 20 AMC rear end
Ok I am going to switch out my rear end to a one peice rear end. I do not understand what keeps the axle in the tube. Do the bearings press on the axle so tight that is what keeps the one peice axle on? How do you know how far to press the bearings on the axle. Is there any threads or pics of the proccess? I tired to find but was not able to find any. Any help would be great.
The brake backing plate holds the axles in.
The bearings go all the way down and the retaining ring gets pressed down to the bearing.
Thanks for moving my thread I noticed it was not right after I hit the button. Old dog does the backing plate go on then the bearing pressed onto the axle? The backing plate holds the bearing on. what keeps the axle from not working off the axle?
Hey driver007. I'm glad you asked that question. I was figuring that, but didn't want to ask. ;)
I'm getting ready to gather parts to install rear brakes on my AMC20
I do not know why but I am having a hard time with the mental picture of what is holding the axle on.
I was reading their install. The bearings are pressed on with a ring. Is the press fit the only thing keeping them from coming loose?
the retaining ring holds the bearing on.(press fit)
The 4 bolts that hold the brake backing plate on is what holds the axle in
as the bearing is to big to fit through the backing plate.
So yes in a way the retaining ring is what keeps the axle from coming out.
This is a pretty common set-up in a lot of different axles.
Thanks Old Dog. I just had a hard time getting it in my head that a pressed on ring is what really is holding the axle from coming out. Have you ever heard of one coming off? there is alot of them out there so it most work. Thanks again
No, never heard of one coming off. It's a pretty hard press. Anything's possible though.
I had a 62' Pontiac le mans that had a transaxle Transmission that the axle came flying out when rounding a corner . That was real crazy. I know some axles are held in with a c-clip at the gear.
Ive never seen that but Ive seen a few 2 piece axles fail. No fun. Pretty much like having the tire and wheel come off with no chance of re assembly. :D Your doing the right thing. :chug:
Yes. If it wasn't for that crucial fit you could pull that axle shaft straight out.
