AMC 304 or 302???
AMC 304 or 302???
I'd go some kind of FI, at least where I wheel the off road Holley's don't do so well.
Thanks folks. Just to clarify what I currently have in the engine bay. It's an AMC 150. Not the chevy 151. I also do not want to put a Chevy v8 or v6 motor in my jeep. I would rather drop in a 258 instead. Thank you guys for staying on topic. The reason I was thinking 302 EFI is because I have lots of problems with my carb now. Tweaking in each season. Auto choke choking out. Off camber flooding or fuel starvation so I figured an EFI would be the ticket. I already have the 304 but it isn't complete. It has about 15 thousand miles on it. It needs a fly wheel, water pump, oil pump, new intake volley pan, and distributor. The boy I got it from took those parts for a 401. Not sure why he took the fly wheel but thats what he and his pop told me. I got the T18 because I wanted a good heavy duty tranns and low first gear. Jeep that I know of did not offer one. So my choice was the SM420, SM 435, or the T18. I didn't care which one. Just whatever I could find first. So T18 it was.
So here is my plan. Let me know what your thoughts are. I have the 304. I plan to have the machine shop install a volley pan, high spark distributor, oil pump, water pump, and mild cam for torque. I plan to keep the stock intake. From what I've read unless using the motor for racing the stock intake is better. I am planning on using the truck avenger carb. I plan to run stock manifolds but true duels. I will have the T18 rebuilt and new rear output shaft installed. I plan to take my time and do this right. I don't have the know how to do the motor work which is why I am having a shop do it for me.
Any other advice at this point???
very cool set up :chug: I would suggest if funds allow strip a whole tbi set up off a 305 chevy and put it on your AMC 304 so that you will have a low dollar efi set up that is easy to get parts for, you can also purchase a new tbi from Howell :chug:
BustedJeep.Com - In The Garage
I'm fixin to pull the 360 in my CJ pretty soon, complete, runs great (different setup going in) and I'll throw in the tranny (SR4 ) with all the clutch stuff if you're interested :rolleyes:
I'm fixin to pull the 360 in my CJ pretty soon, complete, runs great (different setup going in) and I'll throw in the tranny (SR4) with all the clutch stuff if you're interested :rolleyes:
Keep the rest of this conversation in Private Messages or emails ;) Close to the line of "bartering" in open forums. We have a "no buying and selling" in open forums rule.
As I said, you didn't break the rule, but close :D
PS - 360 :drool::drool::drool: :cool:
Where are u located???
$120.00
  60.0%
