Amc20
Amc20
Never 'assume' :eek: ...That can get expensive. :poke:
You're going to be changing the gear oil anyway. When you remove the diff covers, look on the outside of the ring gear. There should be a ring gear and pinion gear tooth count stamped.
Are they an open diffs, or some type of Limited slip?
Are they an open diffs, or some type of limited slip?
I have no idea, I'm getting everything I listed, prior a 3 inch lift kit with leaf springs and shocks, and a straight 6 for $200
Maybe you should ask the seller this.
Having to buy and then have someone set up a R&P due to mismatched ratios can get pricey, really fast.
This rearmed swap is a real nightmare...the Ohio rust has taken its toal!
