Steering Another loose-*** steering post
RI CJ5
North Kingstown, RI, USA
1980 CJ5 with a 1980 AMC 360.
4" lift 33" Coopers.
Fiberglass tub
So I just bought a 1980 CJ5 . 360, 4" lift, 33's. PO did a frame off resto. Beautiful work. Everything is new and tight and clean. But the thing wanders all over the road. I have been searching the web for days but outside of " That's just the way they drive" {which is true to a point, but I had an '85 with 33's and a 3" lift and it wasn't nearly as bad} and "Mine drives nice at 90mph on the highway" which sound like a dream, there is nothing I can see to do. Steering box has no play although I cant adj due to stripped allen nut. So, besides adding a steering stabilizer, which will help but not cure. I can see the springs flex side to side when I turn wheel. Whole body shifts, but don't want to crank shackles any tighter and all tie rod ends are tight. So, are there any other ideas out there?
Thanks in advance, Johnny
Solution
Well, like I said, the toe needed a bit of correction. In about 1/2" or so to about 1/8". The big problem was that the PO, in 'Tightening' the steering box, cranked it all the way down and it was bound up. With one guy on the wheel back and forth, and another on the steering box adjustment screw, the broke loose the screw and backed it out 2 turns or so. the worm gear was binding. That adjustment screw is a small turn, not keep turning until it's tight. Much better now, although i'll still need to tweak it once the weather gets better.
Now on to the Carb. used almost 1/2 a tank going 35 miles round trip! Seems a bit rich!
Solution
I see what you’re saying. Overtighening that screw will definitely cause a very bad binding effect, but not make it wonder side to side. Adjust it at mid steer range only to get rid of play and STOP at that point. Thanks for informing.
$125.00
  62.5%
