Anybody know what the amperage draw on the headlights is?
IOPort51
- Featured
- 5
- Media
- 458
- Garland Texas
- 1977 cj-5
2006 Toyota Tacoma
Yes I am going to use one of those from a cherokee. It could in theory be any vehicle on the market. Im not sure what you mean by the crimps? are you talking about the connections for the relays? some cherokees and YJ have more relays than others due to different accessories.
I am going to take that pdc and rewire it up so that I have my 2 fan relays, fuel pump relay, and head lamp relays if there is room. I am then going to use the starter relay in the PDC to fire my starter (I have a mini torque with built in solenoid) and use the pdc's main power connection to the alternator and completely eliminate the fender solenoid. all my fuses for the fuel injectors, fuel pump, ecm etc will be in the pdc.
Universal GM Chrysler Ford Female Terminal Connector 14 12 AWG 50 Pack - The Repair Connector Store
It could be these but I doubt it. the relays and the fuses have crimp fittings at the inside end of the wire, you can get them out, if you can find the right tool. Terminals are available someplace that would allow you to put your preferred length, color and gauge of wire and re insert it into the plastic pig tail block. Eliminate a splice you don't have to splice a 14 to a 12 or worse yet a 12 to a 14 just because that is what you have. Have you decided what you want to power through this PDC and how many circuits you will need? I can real easy think of 3 circuits for the lights. Then there is the fuel pump and electric fan maybe?
How many does that PDC have?
