Are all T5s the same?
Turtle71
Will any of the T5s from a different make and model vehicle work in a CJ?
I have the T-5 out of a ford thunderbird (supercoupe). I had to send it to the transmisson shop to get the tail peice and output shaft changed. I did this in 1994 and had all the of the parts on hand. Can't remember what it cost but it took them about a day to swap all the stuff over.
I had a '82 CJ7 with a T-5 . When it died I put in a T-18 . The T5 is light duty. Here are your options:i have a 86 cj7 w/ a t5 and it too is starting to grind downshifting...need to be going real slow...was gonna overhaul but if ican buy a trans for same price? are the t18 and t176 direct swap outs?
If a Jeep T-18 falls in your lap you might want to keep it. (Figuratively speaking!!!!!)Why not a jeep t18?![]()
Yep I know novak has them. Kind of costly at $519.00I too have a T18. Actually it's the 2nd CJ I've had with a T18. I'm with you: I love 'em.
Keep in mind even a Ford 18 swap into an '80s CJ will require an adapter from the tranny to the TCase.
Look for a ford f-AMC 150 to f-250 both those trucks came with them. Not sure of the years i think 1968 to 1989. also look for a 2WD they will be cheaper then a 4x4 one you have to change the tail shaft out of them so eather one will work.got a scrap yard buddy...what is the best truck to yank a T18 from?
