Are all T5s the same?
Turtle71
NE Florida
1983 CJ7 258 T5
Will any of the T5s from a different make and model vehicle work in a CJ?
No not all T5s are the same. They made a stronger T-5 called a World Class T5. These were found in some mustangs and other 2WD cars. Converting a 2WD T5 to be used in a Jeep is a big job. The shift mechanism is on the tail-housing so swapping out tail-housing is not so easy. There used to be a kit to replace gears and bearing to rebuild a Jeep T5 into a WC T5 but I don't know if such a kit still exists. Even if you could find one I'm not sure it would be worth it. I say upgrade to a better tranny such as a T-176 or T-18 .
I have the T-5 out of a ford thunderbird (supercoupe). I had to send it to the transmisson shop to get the tail peice and output shaft changed. I did this in 1994 and had all the of the parts on hand. Can't remember what it cost but it took them about a day to swap all the stuff over.
Hey guys arent the gear ratios tighter on the 2WD T5s?
Hmmm....The reason I ask is because I may be in the market for a T-5 soon, and noticed there are many from different vehicles that are priced significantly cheaper than ones directly from a Jeep. Anyone have an idea of the costs to convert them to work?
i have a 86 CJ7 w/ a T-5 and it too is starting to grind downshifting...need to be going real slow...was gonna overhaul but if ican buy a Transmission for same price? are the T-18 and T-176 direct swap outs?
i have a 86 cj7 w/ a t5 and it too is starting to grind downshifting...need to be going real slow...was gonna overhaul but if ican buy a trans for same price? are the t18 and t176 direct swap outs?
I had a '82 CJ7 with a T-5 . When it died I put in a T-18 . The T5 is light duty. Here are your options:
T176 - Medium duty tranny - This will mate to your Dana 300 TCase. It will not bolt up to your bellhousing. You may be able to drill and tap your bellhousing but I don't know for sure. Worst case you can buy a CJ T-176 bellhousing. Both Drive shaft lengths will need to be modified.
T18 - Heavy Duty Tranny - If you go this route get a Ford T18, NOT a Jeep T18. The Jeep T18's were always mated to the Dana 20 and to mate it to your Dana 300 will be more trouble than it's worth.
I did this swap with an adapter from Advanced Adapters but Novak has a similar kit. You will not have to modify the drive shafts.
The ford T18 will mate to your bellhousing but you will have to drill and tap 4 holes.
The kit to mate the Ford T18 to the Dana 300 will include a main (output) shaft you will need to install in the T18.
T18 - Heavy Duty Tranny - If you go this route get a Ford T-18 , NOT a Jeep T18. The Jeep T18's were always mated to the Dana 20 and to mate it to your Dana 300 will be more trouble than it's worth.
The kit to mate the Ford T18 to the Dana 300 will include a main (output) shaft you will need to install in the T18.[/QUOTE]
Why not a jeep t18?:confused:
Thanks for clearing that up Dave:notworthy: I have a jeep T-18 in my 74 CJ5 and love it. Ive been thinking about pulling it out and installing it in my 86 CJ7 i just picked up but think ill pull the T18 out if my 88 half ton ford.
I too have a T-18 . Actually it's the 2nd CJ I've had with a T18. I'm with you: I love 'em.
Keep in mind even a Ford 18 swap into an '80s CJ will require an adapter from the tranny to the TCase.
thanks Busa for the post on the Dana 20 /Dana 300 and the T-18
on of the hardest things about these old Jeeps is we have a lot of different circumstances we need to keep in mind
I know that there is a lot of stuff that sounds easy, but in reality it involves major changes, and that a lot of us here can specialize in just certain areas. I have never dealt with a D300 except wheeling one and would have been blown away if I had pulled one out and saw what you showed us in that post.
As most guys know here, I can talk forever on the drivetrain of any jeep built before 1972, after that I quickly get into guess range.
I love the old stuff, My dream jeep as of now is to find a 1958 CJ5 and build her to factory spec. It would be my pride and joy to run around in a jeep built in the year I was born. I could probably build it in my sleep, only mods would be the disc brakes and a chain drive clutch linkage, I would even run the old 16 inch skinny rims
Yes, in my opinion the T-5 (along with it's brother the T-4 ) are the worst trannies to ever go into a CJ.
Us early guys think the T-86 was the worse, we swap in a T-14 as quick as we can. They used the T86 for 3 year, 65 66 and 67 behind the Dauntless Buick 225 V6 till they found out from the public how fast it was eating itself up, it was a natural to use as it shared the T-90 case but it will spit gears on a mild obstacle. The T14 is much stronger and has a low gear in the 3 range, matched with the 2.48 of the T-18 that gives a low range that matches todays jeeps with the 2.7 np231.
got a scrap yard buddy...what is the best truck to yank a T-18 from?
got a scrap yard buddy...what is the best truck to yank a T18 from?
Look for a ford f-AMC 150 to f-250 both those trucks came with them. Not sure of the years i think 1968 to 1989. also look for a 2WD they will be cheaper then a 4x4 one you have to change the tail shaft out of them so eather one will work.
