Build Thread Aussie CJ7 - 78
IOPort51
- Featured
- 5
- Media
- 458
- Garland Texas
- 1977 cj-5
2006 Toyota Tacoma
looking good Jon. that is the cleanest, sharpest engine I have seen...think you will ever get it started?Nice close up of the header bolted in...those turned out nice...I know it was a lot of work. So the question is...why would you go with extended bump stops? Won't that lower your range of travel?
notice the bottom shock mount and the way it points slightly downward.
this is what happens when the shock bottoms out, believe me when I say that you don't have near the upward travel you may think you have. without changing shock location and/or buying some extreme and expensive shocks, an inch, maybe an inch and a half is the best you can hope for.
In the immortal words of William Jefferson Clinton, "Bump stops are a good thing"
