Axle Swap Question for a 1984 CJ-7
diddy2003
Old Time Jeeper
- Western Massachusetts
- 1984 CJ-7
35x12.5x15 MTRs;
YJ 4 inch Skyjacker lift w/ Bilsteins;
rebuilt AMC 360, Patriot Headers, Holley Truck Avenger 670 CFM, Edelbrock Performer Intake, Flexalite Electric Fan; Griffin Aluminum Radiator, Dual Flowmaster Delta Flow 40s;
Dana 30 4.10s w/ Detroit Truetrac;
Dana 60-2 Narrowed, 11 inch Ford Drum Brakes, 4.10s Power-Lok LSD; NV4500; Dana 300 LoMax 4:1 Twin-Stick; Navajo Power Brake Booster
NV4500 gear ratios
1st gear: 5.61 : 1
2nd gear: 3.04 : 1
3rd gear: 1.67 : 1
4th gear: 1.00 : 1
5th gear (overdrive): 0.75 : 1
Engine speed at 55 mph: 1624 RPM
Engine speed at 65 mph: 1919 RPM
Crawl Ratio: 92 : 1
I have been trying to find a set of axles with 3.73 gears to save me some money from re-gearing my stock Dana 30 /AMC20 setup. I posted wanted adds on various sites and received a phone call today. Ideally I wanted the same axle set-up only with the different gears, but I was open to other options as well.
So I got a call from a guy and he told me that he has a set of 3.73s. They are wide track Dana 30 front and Scout Dana 44 rear with Trac Lok.
Is there any issue to running this set-up? The Scout axle is longer than the 30. Are there spacers available to get them to the same length? How much would it be to shorten the 44? I know the 30 will be a direct bolt in, but what about the 44 rear from the scout?
Thanks for the help. I just want to make sure that this set will be a good option for me.
