Back firing on decelleration
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
Stats
1982 rebuilt AMC 360
Stock 2150 Carb, professionally rebuilt not long ago
Dui HEI distributor set at 12* -the vacuum was disconnected, used stock gear Edit: stock springs. The vacuum was disconnected while setting the distributor as is standard operation.
Inside the rails headers (look to be headmans)
Cats
Flowmaster mufflers
Stock air pump
Problem - The darned thing back pops and takes on with an occasional hard fire on deceleration. It is worse if I've just gotten on it, as in some Lexus driving smart *** tries to cut the CJ off pulling away from a stop light and traffic suddenly slows up. It also happens less so during more mundane times like adjusting speed on the interstate.
I've talked to the carburetor guy. He said the timing was good and the carb seemed good, he had no solution except to say that a leak in the exhaust would do it. The exhaust system looks like new. Frankly it is driving me a little nuts to go rattling and banging along down the road. Disclaimer: it's not really that bad, but the occasional back firing is disconcerting.
So, I'm bringing this to the board in hops that someone might know what to do.
Cats
Flowmaster mufflers
Stock air pump
