Back firing part 2
bearsden
- Media
- 3
- Norwalk,Iowa
- 2002 ford f150 4wd,1989 chevy suburban 4wd,86 cj7 ,67 nissan patrol(sold)
thank you Jdarg i think i will give that a go before tearing into it. It was not loose when i took it apart to fix the freeze plugs in the head and it actually ran fine just leaked antifreeze,so i think i'll try what you said before taking all that apart again!Don't just blindly replace all the lifters, esp. if you are on a budget.
Just how loose is it? It could be as simple as a really worn rocker/fulcrum - a very common issue on these engines, esp. engines with one piece fulcrums, and very cheap/simple to replace if that's the case.
Lifters often don't "fail" - they just get dirty and stuck. You can often free them by running the motor w/ the valve cover off and tap the affected rocker w/ a soft mallet right above where the pushrod meets it. Don't be afraid to give it more than a tap but don't go full ape poopie on it either.
If that seems to help I would run a quart of ATL in lieu of 1 qt. of oil for a while and keep an eye on the filter. That should really help clean things up inside the motor.
