Back left doesn't work in 4wheel
Rust Bucket
Alpharetta, Georgia
'75 CJ5 304 3 speed, '12 GMC Terrain, '07 F-150
So, my front end diff is hosed, but I thought the back left tire would engage in 4wheel. Instead, I have a 4wheel drive Jeep that only functions as a 1wheeler! Sigh!!! I plan on replacing the front end in a dew months, but I need an opinion on the rear. How should the rear end operate? Is it only Limited slip and if so, when should it engage the left?
On a positive note, the best way to learn how your Jeep drives is a six hour offroad trip in 2wheel. These beasts really are the best at what they do!!!!!
So, my front end diff is hosed, but I thought the back left tire would engage in 4wheel. Instead, I have a 4wheel drive Jeep that only functions as a 1wheeler! Sigh!!! I plan on replacing the front end in a dew months, but I need an opinion on the rear. How should the rear end operate? Is it only limited slip and if so, when should it engage the left?
You are finding out how 4-wheel drive works from the ground up.:laugh:
Most Jeeps are 2-Wheel drive one on the front axle & one on the back axle.
Limited slip gives a Limited amount of power to the other side, but not if there is no friction at all. It helps to ride the brakes a little to increase the friction.
For true 4-Wheel drive you might want to consider a "Locking Differential".
They send power to both tires even if one is off the ground.;)
Limited slip gives a limited amount of power to the other side, but not if there is no friction at all. It helps to ride the brakes a little to increase the friction.
Yep X2:chug:
