Best/easiest replacement for quadratrac amc 20
tthstrm179
- CA
- 1978 CJ7 304, Th400, Quadra trac converted to part time and low range
I know that this question has probably been asked before, but I did not find an answer yet.
I have a 78 CJ7 with the AMC 304 and QuadraTrac with low range. The Jeep is mostly stock and I want to upgrade the one piece rear end. The Dana 20 is the quadratrac rear end with the passenger side drop.
Which rear end would be a drop in replacement? I want to stay with the Dana 44 line, so I'm looking for a make/model of a donor vehicle.
The other option would be to put in a Dana 20 from a wagoneer donor vehicle that will bolt up to the GM Turbo 400 . I'm hesitant on doing this due to the overall cost of the project when replacing drivelines and misc. work.
Any thoughts or experience with this?
Thanks in advance guys.
