Build Thread Bi-Centennial CJ-5
Niedhogg
Old Time Jeeper
Thor, Iowa
'79 Jeep CJ7 Renegade with 304ci V8, TH400 auto, Quadratrac T-case, Stock 20 and 30 rears with no mods yet, not sure of the gear ratio.. 4" Softride Superlift, w/widetrac shock towers and 35x12.50x15 BFG Mud-Terrains
'76 CJ5, 232 ci, T-150 3-speed, D20 T-case, Corp. 20 rear w/full float axles and lockout hubs and Detroit auto locker, D30 front w/lockout hubs, gear ratio is unknown..
I can't say I've seen anything quite like those shackles. Don't blame the po for being reluctant to drive it, especially on the street.
YES, you have a full floating rear axle conversion. The warn lock-out hubs are the give-away on that. Usually lock-outs are only on the front ;)
Cool find. Good luck with the project!
You sure do like to make it interesting dont you? :) This outta be fun to watch. :chug:
The 2 steering stabilizers don't counteract the neg caster from the 10" shackles?:laugh:
Probably steers good in reverse.:D
Once you get past the shackle/body lift and imagine it without those awesome bumpers it looks pretty decent. As you move along and the tire size grows in your head (along with the hole in your wallet ) you may not even mind the opened up wheel wells. :)
So, the floating rear axle with lockouts probably means this Jeep was towed behind another vehicle at one time??? Is there any other advantage of this setup?
A full floating axle is a stronger design than a semi float.
You know, I'm of the same mind on this.. the body isn't bad at all. I hadn't paid much attention to it over the last ten years that I've known about it, I knew he rarely drove it and that it was ugly as sin, and the way he always talked, it would NEVER be for sale.. but i started talking to him about it after I got back from PA with my CJ7 , went over one afternoon a couple months ago and took a really good look at it with him, and unbelievably, he said he would sell it to me!
I have got to get that carpet up though, and I'll be starting on that this weekend, downside is, I'll have about a hundred new holes in it after drilling out the rivets...:(
Anti theft device :laugh:
So today maybe, juuust maybe, I get to work on the Jeep.. and this thing will hopefully purr like a kitten..
New cap and rotor are in hand, I have 3-4 gallons of fresh gas to pour into the tank, check the oil and water levels, I will pull the plugs to make sure they CAN make a spark, set the crank on top dead center to make sure the distributer isn't too far off, slip in the battery from my CJ7 and see if we have a winner!
:)You did not mentioned flushing that fuel tank out.......been setting that long the fuel may have turned to jell and may even have some rust? Good Luck!
:D:D:D:D
:D:D:D:D
Good point, Tarry, thanks!
:D I don't think that is going to help it get down the road but looks cool.
I was just playing around, found that old scoop in a pile of junk yesterday while cleaning up and brought back some old memories.. that scoop was on my '70 Charger when I bought it near 20 yrs ago..:D
I had a '68 Charger with a bigblock aww those were the days should have never sold it. :(
No, you shouldn't have.. hind-sight is 20/20.. Mine was originally a 383 4-speed car with a bench seat, only 211 produce with that driveline combo in 1970, but the original engine was long gone before I got the the car. I got a 440 with the purchase, and spent a couple weekends shoehorning that thing in, and what a blast! Drove it for a few years and the tank started leaking so it has been sitting. I have a 6-pack set up for it now, ready to bolt on.. I almost sold mine 6-7 yrs ago.. I was in the middle of restoring it and someone broke into my shop and stole my gauge cluster (tic-toc tach) and they cut the harness, my grill, my gas door, my 6-pack air cleaner, almost got the steering column (4-speed), and left the pistol grip hurst shifter behind as well, thank god.. something must have spooked them or I have no doubt a lot more would have been missing.. They also got a few other things, I had a brand new Holley 850 double pumper, and they got the shaker scoop off my '74 GTO... It was a bad weekend when I walked into the shop, and in the coming weeks I really struggled to hang on to the car.. those are some big ticket items, but I kept it, it's covered in the corner of the shop waiting for me to resurect him again, and I'm slowly collecting the missing pieces.
On a brighter note, I ordered a new distributor for the CJ5 today, I figured it would be worth the 60 bucks and be done with it, so in the next few days it should be running!
