Build Thread Bill's 75 CJ5 ground up rebuild
billyocup
- Arnold, CA
- 75 CJ5 304V8 T15 D20 D44 D30 2 1/2" lift, 05 Victory Kingpin, 2011 GMC Sierra 3500 Diesel 4x4
Well I've got almost everything back to where it was 3 weeks ago, still have to re-install the front drive shaft. Haven't tried to start it yet, but turned it over a few times to make sure the starter is engaging and turning the engine the way it should. Seems to be working fine. Hopefully the weather will cooperate this weekend so I can roll it out of the garage and try to fire it up, but we're supposed to get snow over the next couple of days so who knows.
In the mean time, I installed the steering wheel, got the horn button in and working (probably the first time it's had a horn in 20 years). Have been looking for plugs to fill the wiper linkage access holes at the bottom of the windshield without much luck. A friend suggested using electrical panel knock out plugs. I got some from a friend who is an electrical contractor, but he didn't have the backing part, so I attached a toggle to a screw to hold them in place. I added some neoprene gasket material to the back and painted the fronts. Don't look half bad and seals up the holes.
