Borg Warner T-90 to Chevy 229 v6
Jonathan5235
Port Townsend WA
I just purchased a 1980 Chevy 229 today for $95 that looks to be in good shape and have a few questions about its compatibility with a Borg-Warner T-90 Transmission . I pulled the existing '67 Chevy 350 (It's in real bad shape and doesn't run, though it kills me to downgrade :() out and there is an adapter plate for it on the transmission. I'm wondering if this will this work with the 229, or if the 229 even requires an adapter? Also will the clutch and flywheel work with the 229, or will I need to find new ones?
I'm new to Jeeps, so your input is greatly appreciated. Thanks!
I just purchased a 1980 Chevy 229 today for $95 that looks to be in good shape and have a few questions about its compatibility with a Borg-Warner T-90 trans. I pulled the existing '67 Chevy 350 (It's in real bad shape and doesn't run, though it kills me to downgrade :() out and there is an adapter plate for it on the transmission. I'm wondering if this will this work with the 229, or if the 229 even requires an adapter? Also will the clutch and flywheel work with the 229, or will I need to find new ones?
The 229 (3.8) is to the SBC what a 231 (3.8) is to a Buick: they are the same as their V8 brothers except for year differences. The 4.3 V6 is a direct descendant of the 229. The 229 uses the same bellhousing pattern as the 4.3 and I believe that the adapters should be the same. All chevy engines require an adapter to use with CJ-era trannies as far as I know.
The 229 (3.8) and its little bro the 200 (3.3) were such low-output engines ( below 100 hp IIRC) that they probably aren't included in many swap directories as they are probably very uncommon for swaps. That, and they were only around for 4 or 5 years.
EDIT: found this:
The Chevrolet Small Block V6 Engine - Novak Conversions
You can't find a running chev 350 where you live? They are a dime a dosen here. My buddy bought one a few months ago that was rebuilt for $300
$35.00
  17.5%
