cam bearings...new or not???
LRAYS CJBEAST
I just bought a 81 CJ7 with a AMC 258 i6 / 4.2l . This is my 3rd cj so I'm pretty familiar with the 258 and really like their low end torque and being bulletproof. the motor ran fairly well but had a top end tick..(possible flat cam or bad lifter). I decided to leave motor in and pull head and replace cam, lifters and timing chain and gears and have head and valves ground. Upon removing head and sliding cam out the cam looked worn but not too bad. I inspected cam once out and discovered front cam bearing is slightly worn on cam, but looked a bit rougher inside block. my question is, can I just replace that front one in block without pulling the motor??? Any advice would be appreciated.
Larry
Larry
