Can someone Identify this gear box & crossmember
- Orlando, FL
- 1985 CJ7, AMC 360, lunati cam, AX15, Affordable Fuel Injection, edelbrock performer manifold, 21 gallon fuel tank, Old Man Emu 2.5 inch lift, 1 inch body lift, tie rod flip, HMMWV H1 steering box, rear disc brake conversion, Dana 44 rear, YJ to CJ tub conversion, still working on 33 inch tires, Metallic dark blue paint.
Scrambler Project, cosmetically taking it back to the 80's- 1984 Scrambler, Laredo. 258cc, Holley Sniper EFI, 30in tires on Laredo polished wheels, Dana 44 rear, OME 2.5 YJ springs/lift, HMMWV steering box
Previously owned cj 7, 1979, Renegade, 258 and a '89 wrangler
The original cj came with no crossmember and this gear box sitting in the tub. We purchased a crossmember from a guy who said that the piece belonged to a CJ, but as you can see when I put it on the frame it appears to be 4 inches too wide.
Is this the wrong crossmember? If not I guess I could fabricate my own by cutting the sides and using tubing and a skid plate to make the width correct, but I'm not sure how deep to make it.
As for the gear box, when I pulled the drivetrain with the engine hoist I thought it looked complete with Transmission and Transfer Case (at least to these novice eyes). What is the gear box for?
